How to fix fluid temperature?
Hello, i'm simulating groundloop with loadprofile.
I want to flow 10 Celsius of fluid into the underground heat exchanger, but even if the temperature is designated by Setpoint manager, the simulation flows 18 Celsius fluid.
Is there any other way?
And if I want to set the load profile in minutes, should I use EMS?
