Hi. I'm trying to implement some papers that control a few parameters during runtime. I'm using Gym-Eplus to vary the values but I'm not sure if the following can actually be controlled.
Can we control the frequency of a VFD during runtime using an actuator? (In Hertz)
Is the Return Air Outlet’s Setpoint Temperature similar to what is observed as Return Air Temperature Setpoint in BMS systems?
Can we vary the Fresh Air Damper’s opening percentage in a chiller system during runtime using an actuator?
Can we vary the chilled water valve opening percentage to an AHU system during runtime using an actuator?
I couldn't find any relevant actuators in the .edd file created. Thanks in advance.
