Hi,
I have implemented openstudio-server using the Google Cloud framework and encountered some connection difficulties. When I followed the documentation on google and OpenStudio Server the first time, I was able to set up the OpenStudio Server and run a complete analysis. I then deleted the cluster to save costs. Afterward, I went through the same process several times but failed to get the server running properly; thus, I can't connect to the server via PAT. I have got a message, "Pod unschedulable", on the Google Cloud Console in which it seems like the cluster was not created with enough resources.
Therefore, could anyone please advise on creating a cluster with sufficient resources for a PSO analysis (e.g., disk size, machine type, and number of nodes)?
Thank you so much.
kubectl get pods
NAME READY STATUS RESTARTS AGE
db-759856dc8c-m6qw8 0/1 Pending 0 22m
openstudio-server-nfs-server-provisioner-56ccb8b855-hm4jf 0/1 Pending 0 22m
redis-5b8c9599d6-4jd4c 0/1 Pending 0 22m
rserve-6897979876-fz944 0/1 Pending 0 22m
web-6bd89749cf-5wkbs 0/1 Pending 0 22m
web-background-584868f998-dqqjw 0/1 Pending 0 22m
worker-84fb55698b-722bs 1/1 Running 0 22m
worker-84fb55698b-xpt5w 1/1 Running 0 22m
