Hi,
I have tried manual sampling using resstock with different sample sizes (e.g., 100,120, 1k) and comparing those, I believe that none of the rows between 100 and 120 samples (for example) are similar. If I were to use 100 samples initially and later I decided to increase the number of samples for a region by +50, is there a way to make sure that the additional 50 are the only ones updated/added? (Besides manually adding 50 samples to the buildstock.csv files generated initially?)
Best, Mohammad
