I created the photovoltaic curtain wall by creating a shading surface group and then using the“Add photovoltaic” script.But when I try to export the IDF it generates the warning below:
Warning: Object of type 'OS:ShadingControl' and named 'Shading Control 1' does not control any SubSurfaces, will not be translated
How can I make the fenestration area unshaded when adding photovoltaics? Or is there a better way to add the photovoltaic curtain wall?
