Hello,
I have a question about the 'Surface Heat Storage' output for a drop ceiling surface. The surface energy does not cycle with its temperature as I would expect. Instead, it appears to accumulate "infinite" energy over time.
The linked files are for a Medium Office prototype building I chose to illustrate the issue. I included the heat stored by the Roof, which does cycle with temperature as expected.
IDF and Output file: https://drive.google.com/drive/folders/1n32Q6heH4L4tECSwKilm6UM3EvzYBSy5?usp=sharing Any insight is very much appreciated.
Thank you,
Jason
