I am trying to install buildstockbatch to run and manage batch simulations of ResStock, by applying the buildstockbatch python library installation method (https://buildstockbatch.readthedocs.io/en/latest/installation.html). To my understanding of the images below, it says that it has installed the library, but when I make an attempt to verify if so by buildstock_local -h, buildstock_local is not defined. Can someone please help me understand where I may have interpreted the installation instructions incorrectly or not have executed something properly?
>>import os
>>os.chdir("Downloads")
>>os.chdir(r"C:\Users\akasha.fobbs\Downloads\buildstockbatch-2023.05.0\buildstockbatch-2023.05.0")
>>pip install -e . --user
Successfully installed buildstockbatch
Note: you may need to restart the kernel to use updated packages.
WARNING: s3fs 0.4.2 does not provide the extra 'boto3'
>>buildstock_local -h
File "C:\Users\AKASHA~1.FOB\AppData\Local\Temp/ipykernel_32752/1927210971.py", line 1, in <module>
buildstock_local -h
NameError: name 'buildstock_local' is not defined
