Hi, A simulation in OpenStudio failed due to exit code 1. I have read about this problem in this forum, and suspect that the problem is cause by wrong pathway, since both / and \ is used in the same pathway. Here follow the first line from simulation run (verbose output):
I, [2023-06-16T14:10:05.829056 #15684] INFO -- : CLI Parsed Inputs: ["--verbose"] "run" ["-s", "53445", "-w", "C:/Users/jolind/AppData/Local/Temp/osmodel-1686907196-7\resources\workflow.osw"]
Am I right that the path way is the reason for the error? If so, how do I edit the pathway in OpenStudio Application? Best regards, Johan
