Underfloor system for heating and cooling with Heat pump in openstudio
Hello.
I am trying to create an underfloor system for heating and cooling with the use of heat pump in openstudio.
Till now, i have managed to create an underfloor heating system with gas boiler through creating a plantloop in openstudio and a seperate common cooling system with heat pump.
I was wondering so if there is a possibility to make this combined heating and cooling system and how i could connect plantloop and airloop, by designing an air to water heat pump for both heating and cooling.
Thank you in advance
Hello.
