Hello everyone! I am trying to run a simulation with PythonPlugin within EnergyPlus. I already tried with 9.6 version of EnergyPlus and it works if you copy the required python libraries into "C:\EnergyPlusV9-6\python_standard_lib" directory. On the other hand, when moving to the latest version of EnergyPlus (v23.1 or even 22.2) the SAME worklow doesn't work. When running the co-simulation from EnergyPlus, I got the following error about pandas library.
** Severe ** Failed to import module "PythonPlugin_file" ** ~~~ ** Python error description follows:
** ~~~ ** ModuleNotFoundError("No module named 'pandas._libs.interval'")
** ~~~ ** Python traceback follows: ** ~~~ ** ``` ** ~~~ ** >>> Traceback (most recent call last): ** ~~~ ** >>> File "......\PythonPlugin_file.py", line 13, in <module>
from other_script import* ** ~~~ ** >>> File "......\other_script.py", line 16, in <module>
import pandas as pd ** ~~~ ** >>> File "C:\EnergyPlusV23-1-0\python_standard_lib\pandas\__init__.py", line 22, in <module>
from pandas.compat import is_numpy_dev as _is_numpy_dev # pyright: ignore # noqa:F401 ** ~~~ ** >>> File "C:\EnergyPlusV23-1-0\python_standard_lib\pandas\compat\__init__.py", line 25, in <module>
from pandas.compat.numpy import ( ** ~~~ ** >>> File "C:\EnergyPlusV23-1-0\python_standard_lib\pandas\compat\numpy\__init__.py", line 4, in <module>
from pandas.util.version import Version ** ~~~ ** >>> File "C:\EnergyPlusV23-1-0\python_standard_lib\pandas\util\__init__.py", line 2, in <module>
from pandas.util._decorators import ( # noqa:F401 ** ~~~ **
>>> File "C:\EnergyPlusV23-1-0\python_standard_lib\pandas\util\_decorators.py", line 14, in <module>
from pandas._libs.properties import cache_readonly ** ~~~ **
>>> File "C:\EnergyPlusV23-1-0\python_standard_lib\pandas\_libs\__init__.py", line 13, in <module>
from pandas._libs.interval import Interval ** ~~~ ** >>> ModuleNotFoundError: No module named 'pandas._libs.interval' ** ~~~
** ``` ** Fatal ** Python import error causes program termination
I tried to switch to different pandas versions but it's still giving this error. Btw I am using Spyder of Anaconda so maybe the problem would be that I'm not using Python interface. Otherwise, which do you think is the source of the error? Thank you in advance
