Hi, I want to check the airflow when exhausting air at a constant airflow rate from a particular room and taking in raw outdoor air through a window in another room.(the room is negative pressure ventilation) I made IDF and run simulate but failed with following error messages.
* Severe * The number of entered AirflowNetwork:Distribution:Component:Fan objects is 1
* Severe * The number of entered AirLoopHVAC objects is 0
why I'm getting this error?please tell me.
thanks,
