I have been working on adding measures like geothermal and co-generation systems for a project in OpenStudio application. However, after running the program, I understood that the measures are not effectively applied on the project model as the energy use values remained the same. Below is the ruby code for cogeneration:
start the measure
class CogenerationMeasure < OpenStudio::Measure::ModelMeasure # Define the name and description of the measure def name return 'Cogeneration Measure' end
def description return 'Upon running the measure, the cogeneration system is created using a micro generator object within the OpenStudio model. The user-defined capacity and efficiency values are assigned to the cogeneration system. The measure then adds the cogeneration system to the primary plant loop of the model, ensuring it becomes part of the overall HVAC system.' end
def modeler_description return "By applying the Cogeneration Measure, users can assess the impact of integrating a cogeneration system on their model's energy performance. This measure facilitates the evaluation of the combined electricity and heat generation potential, enabling users to analyze metrics such as energy consumption, demand, and cost savings. The measure serves as a valuable tool for energy efficiency analysis and decision-making regarding the implementation of cogeneration systems in OpenStudio models." end
# Define the measure inputs def arguments(model) args = OpenStudio::Measure::OSArgumentVector.new
# set capacity
capacity = OpenStudio::Measure::OSArgument.makeDoubleArgument('capacity', true)
capacity.setDisplayName('Cogeneration System Capacity')
capacity.setUnits('kW')
capacity.setDefaultValue(150.0)
args << capacity
# set efficiency
efficiency = OpenStudio::Measure::OSArgument.makeDoubleArgument('efficiency', true)
efficiency.setDisplayName('Cogeneration System Efficiency')
efficiency.setUnits('fraction')
efficiency.setDefaultValue(0.8)
args << efficiency
return args
end
# define what happens when the measure is run def run(model, runner, user_arguments) super(model, runner, user_arguments)
# use the built-in error checking
if !runner.validateUserArguments(arguments(model), user_arguments)
return false
end
# assign the user inputs to variables
args = OsLib_HelperMethods.createRunVariables(runner, model, user_arguments, arguments(model))
if !args then return false end
# Get the user inputs
capacity = runner.getDoubleArgumentValue('capacity', user_arguments)
efficiency = runner.getDoubleArgumentValue('efficiency', user_arguments)
# Check if the capacity is valid
if capacity <= 0.0
runner.registerError('Cogeneration system capacity must be a positive value.')
return false
end
# Check if the efficiency is valid
if efficiency <= 0.0 || efficiency > 1.0
runner.registerError('Cogeneration system efficiency must be between 0 and 1.')
return false
end
# Create a cogeneration system object
cogeneration = OpenStudio::Model::GeneratorMicroTurbine.new(model)
cogen = OpenStudio::Model::GeneratorMicroTurbineHeatRecovery.new(model, cogeneration)
cogeneration.setReferenceElectricalPowerOutput(capacity)
cogeneration.setReferenceElectricalEfficiencyUsingLowerHeatingValue(efficiency)
# Add the cogeneration system to the primary plant loop
loop = model.getPlantLoopByName('Hot Water Plant Loop').get
loop.addSupplyBranchForComponent(cogen)
# Report the success of the measure runner.registerInfo('Cogeneration system has been added to the model.')
return true
end end
Register the measure with the OpenStudio MeasureManager
CogenerationMeasure.new.registerWithApplication
