Hey,
is it possible to import (txt, csv) files into EnergyPlus for running time-series simulations (change variabel with every time step). For example: I want to model a concrete core heating/cooling system: The supply temperature and mass flow should be set by measured values (time step 10minutes). Or do I write them by hand into schedules?
Thank you very much;
