How to define fully opaque shades?
Hi,
I modelled two scenarios with fully opaque shades (the first with five facade shades and the second with only one shade at 40 degrees). I expected to have the same cooling energy. But the first scenario in Zone A is 424 kWh, while the second one is 478 kWh. Why are the results different for one shade above another shade? They should be the same. image description
Thanks, Berrak
Hi,
Thanks, Berrak
Hi,
I modelled two scenarios with fully opaque shades (the first with five facade shades and the second with only one shade at 40 degrees). I expected to have the same cooling energy. But the first scenario in Zone A is 424 kWh, while the second one is 478 kWh. Why are the results different for one shade above another shade? They should be the same. image description image description
Thanks, Berrak Berrak
