I would like to build an air loop with configuration as below:
A setpoint manager should be put after the cooling coil to control the humidity ratio.
And I'm doing this through openstudio API in python. When I tried to add those components in order as below, the setpoint manager cannot be placed correctly somehow. It always appears in the position of spm_2.
Does anyone have a clue about resolving this problem? Thanks.
