I am running a model of ground source heat pump system with central forced air system in EnergyPlus, and I am obtaining the following inlet and outlet temperature curves of the heat pump cooling and heating component.
How can I verify if it is working well?.!
It seems strange that the inlet temperature and the outlet temperature does not match when the heat pump is not operating.
Here it is a link for the two pictures and the model if anyone can help.
https://drive.google.com/drive/folders/1nlGxcyQ26EKNCULOOlCCAvJ02umILPkV?usp=sharing
Many thanks in advance.
