I'm working on thermal modeling a single family residential home to compare different exterior wall r-values. I don't really know much about HVAC and heating/cooling systems and it shouldn't matter for my purposes as long as it works, which is why I was trying to use the "Create DEER Building from Model" measure for my needs. I have a weather file, climate zone, and model set but when I try to run the measure I get the error "This is not a table" and I have no idea where to even start with that. I've copied the error log below. Any ideas? Thanks.
Standard Output:
[OpenStudio.Measure] OSRunner is deprecated, use OpenStudio::Measure::OSRunner instead.
[openstudio.EpwFile] Successive data points (1987-Jan-31 to 1971-Feb-01, ending on line 753) are greater than 1 day apart in EPW file 'C:/Users/422029/AppData/Local/Temp/osmodel-1683294222-1/resources/files/USA_NC_Charlotte.723140_TMY2.epw'. Data will be treated as typical (TMY)
[OpenStudio.Measure] OSArgumentMap is deprecated, use OpenStudio::Measure::OSArgumentMap instead.
[10:51:46.295741 ERROR] This is not a table
:/ruby/2.7.0/gems/openstudio-standards-0.3.0/lib/openstudio-standards/standards/Standards.Model.rb:2419:in `model_find_objects'
:/ruby/2.7.0/gems/openstudio-standards-0.3.0/lib/openstudio-standards/standards/Standards.Model.rb:2556:in `model_find_object'
:/ruby/2.7.0/gems/openstudio-standards-0.3.0/lib/openstudio-standards/standards/Standards.SpaceType.rb:24:in `space_type_get_standards_data'
:/ruby/2.7.0/gems/openstudio-standards-0.3.0/lib/openstudio-standards/standards/Standards.SpaceType.rb:119:in `space_type_apply_internal_loads'
:/ruby/2.7.0/gems/openstudio-extension-0.6.0/lib/openstudio/extension/core/os_lib_model_generation.rb:2883:in `block in typical_building_from_model'
:/ruby/2.7.0/gems/openstudio-extension-0.6.0/lib/openstudio/extension/core/os_lib_model_generation.rb:2881:in `each'
:/ruby/2.7.0/gems/openstudio-extension-0.6.0/lib/openstudio/extension/core/os_lib_model_generation.rb:2881:in `typical_building_from_model'
C:/Users/422029/BCL/09cc23db-5e9b-4b11-b167-1852a15ed339/f8a8e7e4-350b-4b0f-a27a-18e1ddf170fd/measure.rb:478:in `run'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:517:in `apply_measure'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:in `block in apply_measures'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `each_index'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `apply_measures'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in `perform'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in `step'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in `run'
:/openstudio_cli.rb:1184:in `execute'
:/openstudio_cli.rb:814:in `execute'
:/openstudio_cli.rb:1983:in `'
eval:188:in `eval'
eval:188:in `require_embedded_absolute'
eval:173:in `block in require_embedded'
eval:167:in `each'
eval:167:in `require_embedded'
eval:126:in `require'
eval:3:in `'
[10:51:46.297531 ERROR] :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb failed with message Runner error :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb failed with This is not a table , :/ruby/2.7.0/gems/openstudio-standards-0.3.0/lib/openstudio-standards/standards/Standards.Model.rb:2419:in `model_find_objects'
eval:188:in `eval'
eval:167:in `each'
eval:3:in `' in :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:545:in `rescue in apply_measure'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:505:in `apply_measure'
eval:188:in `eval'
eval:167:in `each'
eval:3:in `'
[10:51:46.297789 ERROR] Found error in state 'os_measures' with message [":/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb failed with message Runner error :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb failed with This is not a table , :/ruby/2.7.0/gems/openstudio-standards-0.3.0/lib/openstudio-standards/standards/Standards.Model.rb:2419:in `model_find_objects'\n:/ruby/2.7.0/gems/openstudio-standards-0.3.0/lib/openstudio-standards/standards/Standards.Model.rb:2556:in `model_find_object'\n:/ruby/2.7.0/gems/openstudio-standards-0.3.0/lib/openstudio-standards/standards/Standards.SpaceType.rb:24:in `space_type_get_standards_data'\n:/ruby/2.7.0/gems/openstudio-standards-0.3.0/lib/openstudio-standards/standards/Standards.SpaceType.rb:119:in `space_type_apply_internal_loads'\n:/ruby/2.7.0/gems/openstudio-extension-0.6.0/lib/openstudio/extension/core/os_lib_model_generation.rb:2883:in `block in typical_building_from_model'\n:/ruby/2.7.0/gems/openstudio-extension-0.6.0/lib/openstudio/extension/core/os_lib_model_generation.rb:2881:in `each'\n:/ruby/2.7.0/gems/openstudio-extension-0.6.0/lib/openstudio/extension/core/os_lib_model_generation.rb:2881:in `typical_building_from_model'\nC:/Users/422029/BCL/09cc23db-5e9b-4b11-b167-1852a15ed339/f8a8e7e4-350b-4b0f-a27a-18e1ddf170fd/measure.rb:478:in `run'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:517:in `apply_measure'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:in `block in apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `each_index'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in `perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in `step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in `run'\n:/openstudio_cli.rb:1184:in `execute'\n:/openstudio_cli.rb:814:in `execute'\n:/openstudio_cli.rb:1983:in `'\neval:188:in `eval'\neval:188:in `require_embedded_absolute'\neval:173:in `block in require_embedded'\neval:167:in `each'\neval:167:in `require_embedded'\neval:126:in `require'\neval:3:in `' in :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:545:in `rescue in apply_measure'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:505:in `apply_measure'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:in `block in apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `each_index'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in `perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in `step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in `run'\n:/openstudio_cli.rb:1184:in `execute'\n:/openstudio_cli.rb:814:in `execute'\n:/openstudio_cli.rb:1983:in `'\neval:188:in `eval'\neval:188:in `require_embedded_absolute'\neval:173:in `block in require_embedded'\neval:167:in `each'\neval:167:in `require_embedded'\neval:126:in `require'\neval:3:in `'::/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:654:in `rescue in apply_measure'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:651:in `apply_measure'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:in `block in apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `each_index'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in `perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in `step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in `run'\n:/openstudio_cli.rb:1184:in `execute'\n:/openstudio_cli.rb:814:in `execute'\n:/openstudio_cli.rb:1983:in `'\neval:188:in `eval'\neval:188:in `require_embedded_absolute'\neval:173:in `block in require_embedded'\neval:167:in `each'\neval:167:in `require_embedded'\neval:126:in `require'\neval:3:in `'"]}
Standard Error:
run.log:
eval:188:in `eval'
eval:167:in `each'
eval:3:in `'
eval:188:in `eval'
eval:167:in `each'
eval:188:in `eval'
eval:167:in `each'
eval:3:in `'
