Fan power settings of parallel VAV Fan-powered boxes in E+
Hi Guys: Does any body know how to set "Maximum Primary Air Flow Rate" ,"Maximum Secondary Air Flow Rate" ,"Minimum Primary Air Flow Fraction" and "Fan On Flow Fraction" in energyplus to meet G3.1.3.15 "----" Fans in parallel VAV fan-powered boxes shall be sized for 50% of the peak design flow rate and shall be modeled with 0.74 W per L/s fan power. Minimum volume setpoints for fan-powered boxes shall be equal to 30% of peak design flow rate"?
Hi Guys: Does any body know how to set "Maximum Primary Air Flow Rate" ,"Maximum Secondary Air Flow Rate" ,"Minimum Primary Air Flow Fraction" and "Fan On Flow Fraction" in energyplus to meet G3.1.3.15 G3.1.3.14 "----" Fans in parallel VAV fan-powered boxes shall be sized for 50% of the peak design flow rate and shall be modeled with 0.74 W per L/s fan power. Minimum volume setpoints for fan-powered boxes shall be equal to 30% of peak design flow rate"?
