Hi,
Please help. I have a problem when making two windows that it says, "This subsurface was not in the same plane as its base surface" I attached the idf file "Nara Tipikal 3 U.idf" in this gdrive link https://drive.google.com/drive/folders/1g47_SBEAb-lEb75vCvXkZUAxwKVG7LwJ?usp=sharing
the error This sub surface is missing its base surface: A new zone object has been automatically created for this surface. However it is still missing a base surface. Error: FenestrationSurface:Detailed, U_1K03 This sub surface is missing its base surface: A new zone object has been automatically created for this surface. However it is still missing a base surface. Warning: FenestrationSurface:Detailed, U_1K04 This sub surface was not in the same plane as its base surface. It has been automatically fixed.
Error: FenestrationSurface:Detailed, U_1K04 This sub surface is not contained by its base surface.
thank you very much regards, Budijanto
