The answer to my question is provided to some extent in this previous post, but I would like to know how everyone models radiant ceiling panels.
Radiant ceiling panels are usually made of thin aluminum. Chilled water pipes are on the thin alminum panel, and the insulation board is on the chilled water pipes.
I modelled radiant ceiling panels as follows. The thickness of the aluminum panel is 0.002m (2mm).
Construction,
INTERIOR CEILING with Radiant, !- Name
Concrete 150mm, !- Outside Layer
Ceiling air space resistance, !- Layer 2
Polystyrene foam 50mm, !- Layer 3
Aluminum Radiant Panel; !- Layer 4
ConstructionProperty:InternalHeatSource,
Floor Source INTERIOR CEILING, !- Name
INTERIOR CEILING with Radiant, !- Construction Name
3, !- Thermal Source Present After Layer Number
3, !- Temperature Calculation Requested After Layer Number
1, !- Dimensions for the CTF Calculation
0.1, !- Tube Spacing {m}
0; !- Two-Dimensional Temperature Calculation Position {dimensionless}
Material,
Aluminum Radiant Panel, !- Name
MediumSmooth, !- Roughness
0.002, !- Thickness {m}
210, !- Conductivity {W/m-K}
2700, !- Density {kg/m3}
880, !- Specific Heat {J/kg-K}
0.9, !- Thermal Absorptance
0.7, !- Solar Absorptance
0.7; !- Visible Absorptance
Material,
Concrete 150mm, !- Name
MediumRough, !- Roughness
0.15, !- Thickness {m}
1.74, !- Conductivity {W/m-K}
2240, !- Density {kg/m3}
900, !- Specific Heat {J/kg-K}
Material,
Polystyrene foam 50mm, !- Name
0.05, !- Thickness {m}
0.036, !- Conductivity {W/m-K}
43, !- Density {kg/m3}
1210, !- Specific Heat {J/kg-K}
Material:AirGap,
Ceiling air space resistance, !- Name
0.18; !- Thermal Resistance {m2-K/W}
I got the following severe error.
** Severe ** InitConductionTransferFunctions: Found Material that is too thin and/or too highly conductive, material name = ALUMINUM RADIANT PANEL
** ~~~ ** High conductivity Material layers are not well supported for internal source constructions, material conductivity = 210.000 [W/m-K]
** ~~~ ** Material thermal diffusivity = 8.838E-005 [m2/s]
** ~~~ ** Material with this thermal diffusivity should have thickness > 0.39886 [m]
** ~~~ ** Material may be too thin to be modeled well, thickness = 2.00000E-003 [m]
** ~~~ ** Material with this thermal diffusivity should have thickness > 3.00000E-003 [m]
The simulation completed successfully. Can I ignore the severe error? Or should I follow the severe error message and change the thickness of alminum panel to 0.4m? 0.4m thick aluminum panels are unrealistic. Changing the thickness naturally changes the energy consumption. The high conductivity of the aluminium panel is also important for radiant cooling and should not be reduced. How does everyone model the radiant ceiling panels i.e. as per reality or considering EnergyPlus characteristics?
The idf files (V22-2-0) are here for reference.
