Hi,
I have an error for one conditioned space: "Gross Rated Total Cooling Capacity [W] will be limited by the maximum rated volume flow per rated total capacity ratio".
The error is
* Warning * SizeDXCoil Coil:Cooling:DX:SingleSpeed KAMAR TIDUR UTAMA PTAC COOLING COIL
* ~~~ * ...Gross Rated Total Cooling Capacity [W] will be limited by the maximum rated volume flow per rated total capacity ratio.
* ~~~ * ...DX coil volume flow rate ( m3/s ) = 5.633887E-002
* ~~~ * ...Requested capacity ( W ) = 925.606
* ~~~ * ...Requested flow/capacity ratio ( m3/s/W ) = 6.086E-005
* ~~~ * ...Maximum flow/capacity ratio ( m3/s/W ) = 6.041E-005
* ~~~ * ...Adjusted capacity ( W ) = 932.608
Hot to fix this issue? would you please find the idf file (master.idf) in the gdrive https://drive.google.com/drive/folders/1g47_SBEAb-lEb75vCvXkZUAxwKVG7LwJ?usp=sharing
thank you very much in advance regards, Budijanto Chandra
