Hello! I'm trying to figure out how to simulate a one-story model with OpenStudio, but it always gets crashed when I run the simulation. I've been looking it up and tried to check my model on Youtube but could not find any solution yet. Can someone help to locate the errors in my simulation and tell me what to do? Many thanks!
I, [2023-04-19T10:48:49.447723 #11696] INFO -- : CLI Parsed Inputs: ["--verbose"] "run" ["-s", "64340", "-w", "C:/Users/?????/AppData/Local/Temp/osmodel-1681871678-0\\resources\\workflow.osw"]
D, [2023-04-19T10:48:49.447837 #11696] DEBUG -- : Main arguments are ["--verbose"]
D, [2023-04-19T10:48:49.447869 #11696] DEBUG -- : Sub-command is run
D, [2023-04-19T10:48:49.447910 #11696] DEBUG -- : Sub-arguments are ["-s", "64340", "-w", "C:/Users/?????/AppData/Local/Temp/osmodel-1681871678-0\resources\workflow.osw"]
D, [2023-04-19T10:48:49.448100 #11696] DEBUG -- : Parsing main_args ["--verbose"]
D, [2023-04-19T10:48:49.753462 #11696] DEBUG -- : Adding dependency on jaro_winkler '~> 1.5.4'
D, [2023-04-19T10:48:49.753590 #11696] DEBUG -- : Adding dependency on pycall '~> 1.2.1'
D, [2023-04-19T10:48:49.753633 #11696] DEBUG -- : Adding dependency on sqlite3 '~> 1.3.13.20180326210955'
D, [2023-04-19T10:48:49.753669 #11696] DEBUG -- : Adding dependency on tbd '~> 3.0.3'
D, [2023-04-19T10:48:49.753701 #11696] DEBUG -- : Adding dependency on addressable '~> 2.8.1'
D, [2023-04-19T10:48:49.754203 #11696] DEBUG -- : Adding dependency on ansi '~> 1.5.0'
D, [2023-04-19T10:48:49.754247 #11696] DEBUG -- : Adding dependency on ast '~> 2.4.2'
D, [2023-04-19T10:48:49.754284 #11696] DEBUG -- : Adding dependency on bcl '~> 0.7.1'
D, [2023-04-19T10:48:49.754314 #11696] DEBUG -- : Adding dependency on builder '~> 3.2.4'
D, [2023-04-19T10:48:49.754343 #11696] DEBUG -- : Adding dependency on bundler '~> 2.1.4'
D, [2023-04-19T10:48:49.754370 #11696] DEBUG -- : Adding dependency on docile '~> 1.4.0'
D, [2023-04-19T10:48:49.754397 #11696] DEBUG -- : Adding dependency on faraday '~> 1.0.1'
D, [2023-04-19T10:48:49.754423 #11696] DEBUG -- : Adding dependency on git '~> 1.12.0'
D, [2023-04-19T10:48:49.754453 #11696] DEBUG -- : Adding dependency on json-schema '~> 2.7.0'
D, [2023-04-19T10:48:49.754482 #11696] DEBUG -- : Adding dependency on macaddr '~> 1.7.2'
D, [2023-04-19T10:48:49.754511 #11696] DEBUG -- : Adding dependency on matrix '~> 0.4.2'
D, [2023-04-19T10:48:49.754538 #11696] DEBUG -- : Adding dependency on minitar '~> 0.9'
D, [2023-04-19T10:48:49.754566 #11696] DEBUG -- : Adding dependency on minitest '~> 5.14.4'
D, [2023-04-19T10:48:49.754593 #11696] DEBUG -- : Adding dependency on minitest-reporters '~> 1.4.3'
D, [2023-04-19T10:48:49.754619 #11696] DEBUG -- : Adding dependency on msgpack '~> 1.4.2'
D, [2023-04-19T10:48:49.755203 #11696] DEBUG -- : Adding dependency on multipart-post '~> 2.2.3'
D, [2023-04-19T10:48:49.755239 #11696] DEBUG -- : Adding dependency on octokit '~> 4.18.0'
D, [2023-04-19T10:48:49.755270 #11696] DEBUG -- : Adding dependency on oga '~> 3.2'
D, [2023-04-19T10:48:49.755299 #11696] DEBUG -- : Adding dependency on openstudio-extension '~> 0.6.0'
D, [2023-04-19T10:48:49.755327 #11696] DEBUG -- : Adding dependency on openstudio-standards '~> 0.3.0'
D, [2023-04-19T10:48:49.755355 #11696] DEBUG -- : Adding dependency on openstudio-workflow '~> 2.3.1'
D, [2023-04-19T10:48:49.755382 #11696] DEBUG -- : Adding dependency on openstudio_measure_tester '~> 0.3.2'
D, [2023-04-19T10:48:49.755409 #11696] DEBUG -- : Adding dependency on oslg '~> 0.2.5'
D, [2023-04-19T10:48:49.755436 #11696] DEBUG -- : Adding dependency on osut '~> 0.2.7'
D, [2023-04-19T10:48:49.755489 #11696] DEBUG -- : Adding dependency on parallel '~> 1.19.1'
D, [2023-04-19T10:48:49.755531 #11696] DEBUG -- : Adding dependency on parser '~> 3.1.2.1'
D, [2023-04-19T10:48:49.755561 #11696] DEBUG -- : Adding dependency on public_suffix '~> 5.0.0'
D, [2023-04-19T10:48:49.755591 #11696] DEBUG -- : Adding dependency on rainbow '~> 3.1.1'
D, [2023-04-19T10:48:49.755619 #11696] DEBUG -- : Adding dependency on rake '~> 13.0.6'
D, [2023-04-19T10:48:49.755646 #11696] DEBUG -- : Adding dependency on rchardet '~> 1.8.0'
D, [2023-04-19T10:48:49.755679 #11696] DEBUG -- : Adding dependency on regexp_parser '~> 2.6.0'
D, [2023-04-19T10:48:49.755707 #11696] DEBUG -- : Adding dependency on rexml '~> 3.2.5'
D, [2023-04-19T10:48:49.755735 #11696] DEBUG -- : Adding dependency on rubocop '~> 1.15.0'
D, [2023-04-19T10:48:49.755762 #11696] DEBUG -- : Adding dependency on rubocop-ast '~> 1.23.0'
D, [2023-04-19T10:48:49.756175 #11696] DEBUG -- : Adding dependency on rubocop-checkstyle_formatter '~> 0.4.0'
D, [2023-04-19T10:48:49.756209 #11696] DEBUG -- : Adding dependency on rubocop-performance '~> 1.11.5'
D, [2023-04-19T10:48:49.756238 #11696] DEBUG -- : Adding dependency on ruby-ll '~> 2.1.2'
D, [2023-04-19T10:48:49.756266 #11696] DEBUG -- : Adding dependency on ruby-ole '~> 1.2.12.2'
D, [2023-04-19T10:48:49.756294 #11696] DEBUG -- : Adding dependency on ruby-progressbar '~> 1.11.0'
D, [2023-04-19T10:48:49.756320 #11696] DEBUG -- : Adding dependency on rubyzip '~> 2.3.2'
D, [2023-04-19T10:48:49.756347 #11696] DEBUG -- : Adding dependency on sawyer '~> 0.8.2'
D, [2023-04-19T10:48:49.756373 #11696] DEBUG -- : Adding dependency on simplecov '~> 0.18.5'
D, [2023-04-19T10:48:49.756400 #11696] DEBUG -- : Adding dependency on simplecov-html '~> 0.12.3'
D, [2023-04-19T10:48:49.756427 #11696] DEBUG -- : Adding dependency on spreadsheet '~> 1.2.9'
D, [2023-04-19T10:48:49.756485 #11696] DEBUG -- : Adding dependency on systemu '~> 2.6.5'
D, [2023-04-19T10:48:49.756572 #11696] DEBUG -- : Adding dependency on topolys '~> 0.6.0'
D, [2023-04-19T10:48:49.756615 #11696] DEBUG -- : Adding dependency on unicode-display_width '~> 2.3.0'
D, [2023-04-19T10:48:49.756646 #11696] DEBUG -- : Adding dependency on uuid '~> 2.3.9'
D, [2023-04-19T10:48:49.756675 #11696] DEBUG -- : Adding dependency on yamler '~> 0.1.0'
D, [2023-04-19T10:48:49.756703 #11696] DEBUG -- : Adding dependency on zliby '~> 0.0.5'
D, [2023-04-19T10:48:49.796972 #11696] DEBUG -- : Processing 55 activation requests
D, [2023-04-19T10:48:49.804192 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/bundler/specifications/jaro_winkler-1.5.4.gemspec
D, [2023-04-19T10:48:49.804694 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/bundler/specifications/pycall-1.2.1.gemspec
D, [2023-04-19T10:48:49.804863 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/bundler/specifications/sqlite3-1.3.13.20180326210955.gemspec
D, [2023-04-19T10:48:49.805074 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/public_suffix-5.0.0.gemspec
D, [2023-04-19T10:48:49.805166 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/addressable-2.8.1.gemspec
D, [2023-04-19T10:48:49.805255 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/json-schema-2.7.0.gemspec
D, [2023-04-19T10:48:49.805355 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/oslg-0.2.5.gemspec
D, [2023-04-19T10:48:49.805424 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/osut-0.2.7.gemspec
D, [2023-04-19T10:48:49.805597 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/matrix-0.4.2.gemspec
D, [2023-04-19T10:48:49.805722 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/topolys-0.6.0.gemspec
D, [2023-04-19T10:48:49.805818 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/bundler/specifications/tbd-3.0.3.gemspec
D, [2023-04-19T10:48:49.805943 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/ansi-1.5.0.gemspec
D, [2023-04-19T10:48:49.806016 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/ast-2.4.2.gemspec
D, [2023-04-19T10:48:49.806103 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/zliby-0.0.5.gemspec
D, [2023-04-19T10:48:49.806226 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/yamler-0.1.0.gemspec
D, [2023-04-19T10:48:49.806317 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/systemu-2.6.5.gemspec
D, [2023-04-19T10:48:49.806388 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/macaddr-1.7.2.gemspec
D, [2023-04-19T10:48:49.806484 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/uuid-2.3.9.gemspec
D, [2023-04-19T10:48:49.806572 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/ruby-ole-1.2.12.2.gemspec
D, [2023-04-19T10:48:49.806650 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/spreadsheet-1.2.9.gemspec
D, [2023-04-19T10:48:49.806719 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/rubyzip-2.3.2.gemspec
D, [2023-04-19T10:48:49.806825 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/rexml-3.2.5.gemspec
D, [2023-04-19T10:48:49.806893 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/simplecov-html-0.12.3.gemspec
D, [2023-04-19T10:48:49.806966 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/docile-1.4.0.gemspec
D, [2023-04-19T10:48:49.807038 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/simplecov-0.18.5.gemspec
D, [2023-04-19T10:48:49.807135 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/unicode-display_width-2.3.0.gemspec
D, [2023-04-19T10:48:49.807212 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/ruby-progressbar-1.11.0.gemspec
D, [2023-04-19T10:48:49.807277 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/parser-3.1.2.1.gemspec
D, [2023-04-19T10:48:49.807374 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/rubocop-ast-1.23.0.gemspec
D, [2023-04-19T10:48:49.807450 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/regexp_parser-2.6.0.gemspec
D, [2023-04-19T10:48:49.807526 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/rainbow-3.1.1.gemspec
D, [2023-04-19T10:48:49.807605 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/parallel-1.19.1.gemspec
D, [2023-04-19T10:48:49.807670 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/rubocop-1.15.0.gemspec
D, [2023-04-19T10:48:49.807814 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/rubocop-checkstyle_formatter-0.4.0.gemspec
D, [2023-04-19T10:48:49.807892 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/rubocop-performance-1.11.5.gemspec
D, [2023-04-19T10:48:49.807984 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/rake-13.0.6.gemspec
D, [2023-04-19T10:48:49.808061 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/builder-3.2.4.gemspec
D, [2023-04-19T10:48:49.808126 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/minitest-5.14.4.gemspec
D, [2023-04-19T10:48:49.808201 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/minitest-reporters-1.4.3.gemspec
D, [2023-04-19T10:48:49.808285 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/rchardet-1.8.0.gemspec
D, [2023-04-19T10:48:49.808358 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/git-1.12.0.gemspec
D, [2023-04-19T10:48:49.808454 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/openstudio_measure_tester-0.3.2.gemspec
D, [2023-04-19T10:48:49.808627 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/minitar-0.9.gemspec
D, [2023-04-19T10:48:49.808705 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/multipart-post-2.2.3.gemspec
D, [2023-04-19T10:48:49.808772 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/faraday-1.0.1.gemspec
D, [2023-04-19T10:48:49.808867 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/bcl-0.7.1.gemspec
D, [2023-04-19T10:48:49.809015 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/bundler-2.1.4.gemspec
D, [2023-04-19T10:48:49.809083 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/msgpack-1.4.2.gemspec
D, [2023-04-19T10:48:49.809197 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/sawyer-0.8.2.gemspec
D, [2023-04-19T10:48:49.809294 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/octokit-4.18.0.gemspec
D, [2023-04-19T10:48:49.809399 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/ruby-ll-2.1.2.gemspec
D, [2023-04-19T10:48:49.809521 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/oga-3.2.gemspec
D, [2023-04-19T10:48:49.809681 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/openstudio-workflow-2.3.1.gemspec
D, [2023-04-19T10:48:49.809771 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/openstudio-extension-0.6.0.gemspec
D, [2023-04-19T10:48:49.809918 #11696] DEBUG -- : Activating gem :/ruby/2.7.0/specifications/openstudio-standards-0.3.0.gemspec
D, [2023-04-19T10:48:49.810250 #11696] DEBUG -- : Invoking command class: Run ["-s", "64340", "-w", "C:/Users/?????/AppData/Local/Temp/osmodel-1681871678-0\resources\workflow.osw"]
I, [2023-04-19T10:48:49.810280 #11696] INFO -- : Run, sub_argv = ["-s", "64340", "-w", "C:/Users/?????/AppData/Local/Temp/osmodel-1681871678-0\resources\workflow.osw"]
D, [2023-04-19T10:48:49.811273 #11696] DEBUG -- : Run command: [] {:debug=>false, :no_simulation=>false, :osw_path=>"C:/Users/?????/AppData/Local/Temp/osmodel-1681871678-0\resources\workflow.osw", :post_process=>false, :ep_json=>false, :ft_options=>{}, :show_stdout=>false, :add_timings=>false, :style_stdout=>false, :socket=>"64340"}
[10:48:50.448204 DEBUG] Path for the OSW: C:/Users/?????/AppData/Local/Temp/osmodel-1681871678-0\resources\workflow.osw
[10:48:50.474126 DEBUG] Initializing run method
Error executing argv: ["--verbose", "run", "-s", "64340", "-w", "C:/Users/?????/AppData/Local/Temp/osmodel-1681871678-0\resources\workflow.osw"]
Error: Invalid argument @ realpath_rec - C:/Users/????? in eval:510:in realpath'
eval:510:inrealpath'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:141:in realpath'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:141:inblock in initialize'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/registry.rb:67:in register'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:141:ininitialize'
:/openstudio_cli.rb:1181:in new'
:/openstudio_cli.rb:1181:inexecute'
:/openstudio_cli.rb:814:in execute'
:/openstudio_cli.rb:1983:in<main>'
eval:188:in eval'
eval:188:inrequire_embedded_absolute'
eval:173:in block in require_embedded'
eval:167:ineach'
eval:167:in require_embedded'
eval:126:inrequire'
eval:3:in `<main>'
Simulation failed to run, with exit code 1
