Hi all -- I'm fairly new to EnergyPlus/OpenStudio and I'm wondering if there's a way to use the EnergyPlus components in OpenStudio (i.e., in the same way that you can use BCL measures). I'm particularly after the components ZoneCoolTower:Shower and ZoneEarthtube. Is there a way to 'convert' EnergyPlus components into OpenStudio through a script? Thanks in advance!
