I wasn't getting any errors with my two story home (with a basement) until I tried simulating it with the heat balance algorithm: finite difference method (it works with the conduction transfer function). Then it started giving me this error which I believe pertains to the way I defined heat transfer from the basement walls/floor and the surrounding ground but am unsure how to fix the temperatures of the ground?
This is the full description of the error: Severe * Site:GroundDomain:BasementDoEndOfIterationOperations: Out of range temperatures detected in the ground domain. * ~~~ * This could be due to the size of the loads on the domain. * ~~~ * Verify inputs are correct. If problem persists, notify EnergyPlus support. * Fatal ** Preceding error(s) cause program termination
Thanks kindly!
