Hello,
(sorry in advance for the English)
So I have the following scheme,
1) Boiler----Pump1-----Plate Heat Exchanger----Boiler 2) Plate Heat Exchanger-------Pump2------Water Tank--------Plate Heat Exchanger 3) Water Tank------3 way Valve-----Showers------Pump3------Water Tank
I am new in the modeling, can any one please guide me.
Do I have to create 3 water plant loop, and go from there?
I´m using Openstudio 1.7.5 and Energyplus 8.3
Thanks for the help
Do I have to change drastically the solution that was provide?
