I downloaded building energy models (XML files) from NREL's data repository (https://data.openei.org/s3_viewer?bucket=oedi-data-lake&prefix=nrel-pds-building-stock%2Fend-use-load-profiles-for-us-building-stock%2F2022%2Fresstock_tmy3_release_1%2Fbuilding_energy_models%2Fupgrade%3D0%2F). I intend to convert the files I fetched from here to OSM files so I can use them to run scenarios on PAT. However, when I try to do that, it gives the following error. I tried running the existing sample file measures (base.xml, for example), and they run fine. I wonder what the issue may be with the ones I downloaded from NREL's repository? Is there a way to convert these XML files to OSM?
This element is not expected. Expected is ( SystemIdentifier ). at C:/OpenStudio-HPXML-1.5.1/workflow/sample_files/in_11848.xml:739 Error: Element 'DuctType': This element is not expected. Expected is ( SystemIdentifier ). at C:/OpenStudio-HPXML-1.5.1/workflow/sample_files/in_11848.xml:746
I appreciate any help I can get. Thanks!
