Hello Erik, I just signed in UnMet because I found a discussion in Github related to Openstudio crash at starting based on version 2.9 and below. (versions that can run with a free sketch up version, that a use with my students); I encouter the same problem as you with my dell xps 13. Did you find a way to avoid the crash at starting ? Thanks a lot for your help !
