Hello! I am using EnergyPlus 9.1 and I am using the AirFlow Network function. I need to generate the operating temperature results of 356 thermal zones. However, after finishing the simulation, when I open the .csv file, I don't have the result of all the thermal zones. This has happened twice with different files. I did a test running in OpenStudio and the result of the average temperature of all zones comes out there, but energy plus does not come out. I would like to know if there is a limit of thermal zones in the model, or what other error could be happening so that the temperature result in all thermal zones does not come out through Energyplus.
