Hey, I get the following error any time a run a simulation in OpenStudio. If i delete 'OpenStudio Results' Reporting Measure, the simulation runs without any Error. Does someone have an idea what the problem could be here?
Thanks a lot!
[12:40:43.626553 ERROR] Found error in state 'reporting_measures' with message ["917: Infinity not allowed in JSON::/ruby/2.7.0/json/common.rb:286:in
generate'\n:/ruby/2.7.0/json/common.rb:286:inpretty_generate'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/adapters/output/local.rb:111:inblock in communicate_measure_attributes'\neval:445:inopen'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/adapters/output/local.rb:110:incommunicate_measure_attributes'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:122:inperform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:instep'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:inrun'\n:/openstudio_cli.rb:1184:inexecute'\n:/openstudio_cli.rb:814:inexecute'\n:/openstudio_cli.rb:1983:in<main>'\neval:188:ineval'\neval:188:inrequire_embedded_absolute'\neval:173:inblock in require_embedded'\neval:167:ineach'\neval:167:inrequire_embedded'\neval:126:inrequire'\neval:3:in<main>'"]}
