EnergyPlus API on Apple Silicon Macs
Hi All,
Beginning to cut my teeth on the world of OpenStudio and E+. I wanted to try calling the API through python on my Apple Silicon Mac and got a dlopen error for being on an arm64 system vs x86_64 when assigning the api (my_api =EnergyPlusAPI()). I downloaded the correct E+ version for my system and have been able to run simulations through eppy and using E+ in the terminal itself. Has anyone encountered this? Still a newbie so not sure if there is something simple I'm overlooking. Some research has pointed me to a possible issue with using Anaconda, but haven't been able to narrow it down.
Full print out of error is below: dlopen(/Applications/EnergyPlus-22-2-0/libenergyplusapi.dylib, 0x0006): tried: '/Applications/EnergyPlus-22-2-0/libenergyplusapi.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64')), '/System/Volumes/Preboot/Cryptexes/OS/Applications/EnergyPlus-22-2-0/libenergyplusapi.dylib' (no such file), '/Applications/EnergyPlus-22-2-0/libenergyplusapi.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64')), '/Applications/EnergyPlus-22-2-0/libenergyplusapi.22.2.0.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64')), '/System/Volumes/Preboot/Cryptexes/OS/Applications/EnergyPlus-22-2-0/libenergyplusapi.22.2.0.dylib' (no such file), '/Applications/EnergyPlus-22-2-0/libenergyplusapi.22.2.0.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64'))EDIT: After more research and digging, the problem WAS Anaconda Python. It seems this was running through Rosetta rather than native on the system (a common problem from what I have discovered). Using a different interpreter (Mambaforge for example) with a native Apple Silicon installer seems to have fixed the issue. I hope this helps someone in the future!
Thanks!
