Solar PV Addition to home causes simulation to fail
I'm trying to model PV for a home with a crawlspace foundation, but the optimization algorithm keeps ignoring all PV options I've listed. I created a second case to test what would happen if I mandated PV without an option for no PV, and the simulation failed immediately and produced the following errors. Is this a bug? PV options have been considered for other models I've simulated, the only notable difference being the foundation type. See model here
2/27/2023 7:31 PM:  24.xml:  Warning: No dishwasher specified, the model will not include dishwasher energy use.
2/27/2023 7:31 PM:  24.xml:  Error: Measure Failed with Error: undefined method `+' for nil:NilClass
2/27/2023 7:31 PM:  24.xml:  Error: ** Severe  ** CheckWarmupConvergence: Loads Initialization, Zone="AIR SOURCE HEAT PUMP AIRLOOP RET AIR ZONE" did not converge after 25 warmup days.
2/27/2023 7:31 PM:  24.xml:  Error: **   ~~~   ** See Warmup Convergence Information in .eio file for details.
2/27/2023 7:31 PM:  24.xml:  Error: **   ~~~   ** ...Environment(RunPeriod)="RUN PERIOD 1"
2/27/2023 7:31 PM:  24.xml:  Error: **   ~~~   ** ..Max Temp Comparison = 0.11 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
2/27/2023 7:31 PM:  24.xml:  Error: **   ~~~   ** ..Min Temp Comparison = 0.15 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
2/27/2023 7:31 PM:  24.xml:  Error: **   ~~~   ** ..Max Heat Load Comparison = 0.1249 vs Loads Convergence Tolerance=4.00E-002 - Fail Convergence
2/27/2023 7:31 PM:  24.xml:  Error: **   ~~~   ** ..Max Cool Load Comparison = 4.8705E-002 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence
2/27/2023 7:31 PM:  24.xml:  Error: ** Severe  ** CheckWarmupConvergence: Loads Initialization, Zone="LIVING SPACE" did not converge after 25 warmup days.
2/27/2023 7:31 PM:  24.xml:  Error: **   ~~~   ** ..Max Temp Comparison = 0.35 vs Temperature Convergence Tolerance=0.40 - Pass Convergence
2/27/2023 7:31 PM:  24.xml:  Error: **   ~~~   ** ..Min Temp Comparison = 0.42 vs Temperature Convergence Tolerance=0.40 - Fail Convergence
2/27/2023 7:31 PM:  24.xml:  Error: **   ~~~   ** ..Max Heat Load Comparison = 1.8014E-002 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence
2/27/2023 7:31 PM:  24.xml:  Error: **   ~~~   ** ..Max Cool Load Comparison = 0.0000 vs Loads Convergence Tolerance=4.00E-002 - Pass Convergence
