I'm trying to set an optional double in the CoilCoolingDXTwoSpeed class. The SDK documentation mentions that the parameter will be set to autosize if the value is false or a value is specified if provided.
The C++ code for this component is:
// N1 , \field Rated High Speed Total Cooling Capacity
OptionalDouble CoilCoolingDXTwoSpeed_Impl::ratedHighSpeedTotalCoolingCapacity() const
return getDouble(OS_Coil_Cooling_DX_TwoSpeedFields::RatedHighSpeedTotalCoolingCapacity);
void CoilCoolingDXTwoSpeed_Impl::setRatedHighSpeedTotalCoolingCapacity( OptionalDouble value )
if(value)
setDouble(OS_Coil_Cooling_DX_TwoSpeedFields::RatedHighSpeedTotalCoolingCapacity,*value);
else
setString(OS_Coil_Cooling_DX_TwoSpeedFields::RatedHighSpeedTotalCoolingCapacity,"Autosize");
I'm struggling with the appropriate syntax in the Python bindings to make this work. The command:
coil.setRatedHighSpeedTotalCoolingCapacity(False)
gives the following error:
TypeError: in method 'CoilCoolingDXTwoSpeed_setRatedHighSpeedTotalCoolingCapacity', argument 2 of type 'boost::optional< double
I actually get the same error if a double value is provided.
coil.setRatedHighSpeedTotalCoolingCapacity(10000.0)
Is there a specific syntax required to provide the value as an optional double?
