(This post is slightly related to my previous post about SwimmingPool:Indoor.)
I want to use LoadProfile:Plant in conjection with many Coil:Heating:Water objects in a hot water plant loop as shown below.
I already know 8760 hours of load profile for LoadProfile:Plant, but the entire load in the hot water loop is unknon. So, I want to simulate sizing run and autosize the boiler, pump and heating coils.
LoadProfile:Plant is used with ScheduleFile. I also know the load profile for LoadProfile:Plant on WinterDesignDay and SummerDesignDay. However, the load profile on DesignDays cannot be input to ScheduleFile. How can I set set load of LoadProfile:Plant on DesignDays?
According to Application Guide for EMS, it seems that "CurrentEnvironment == 1" represents WinterDesignDay when WinterDesignDay is Obj1 of SizingPeriod:DesignDay. I tried to override ScheduleFile during the sizing run with EMS, but my EMS input does not work for now. During the design days, EnergyPlus refers to loads on the same date as the sizing day in ScheduleFile i.e. load on January 21st for WinterSizingDay in my case.
I would appreciate it if anyone could correct my EMS input below or advise any other way to set LoadProfile:Plant on DesignDays.
! CHICAGO_IL_USA Annual Heating 99% Design Conditions DB, MaxDB= -17.3°C
SizingPeriod:DesignDay,
CHICAGO_IL_USA Annual Heating 99% Design Conditions DB, !- Name
1, !- Month
21, !- Day of Month
WinterDesignDay, !- Day Type
-17.3, !- Maximum Dry-Bulb Temperature {C}
0.0, !- Daily Dry-Bulb Temperature Range {deltaC}
, !- Dry-Bulb Temperature Range Modifier Type
, !- Dry-Bulb Temperature Range Modifier Day Schedule Name
Wetbulb, !- Humidity Condition Type
-17.3, !- Wetbulb or DewPoint at Maximum Dry-Bulb {C}
, !- Humidity Condition Day Schedule Name
, !- Humidity Ratio at Maximum Dry-Bulb {kgWater/kgDryAir}
, !- Enthalpy at Maximum Dry-Bulb {J/kg}
, !- Daily Wet-Bulb Temperature Range {deltaC}
99063., !- Barometric Pressure {Pa}
4.9, !- Wind Speed {m/s}
270, !- Wind Direction {deg}
No, !- Rain Indicator
No, !- Snow Indicator
No, !- Daylight Saving Time Indicator
ASHRAEClearSky, !- Solar Model Indicator
, !- Beam Solar Day Schedule Name
, !- Diffuse Solar Day Schedule Name
, !- ASHRAE Clear Sky Optical Depth for Beam Irradiance (taub) {dimensionless}
, !- ASHRAE Clear Sky Optical Depth for Diffuse Irradiance (taud) {dimensionless}
0.0; !- Sky Clearness
Schedule:File,
Swimming_Pool_Load_Schedule, !- Name
, !- Schedule Type Limits Name
C:\Project\Swimming_Pool_Load_Schedule\Swimming_Pool_Load_Schedule.csv, !- File Name
2, !- Column Number
1, !- Rows to Skip at Top
8760, !- Number of Hours of Data
Comma, !- Column Separator
No, !- Interpolate to Timestep
60, !- Minutes per Item
No; !- Adjust Schedule for Daylight Savings
LoadProfile:Plant,
Swimming_Pool, !- Name
Swimming_Pool Inlet, !- Inlet Node Name
Swimming_Pool Outlet, !- Outlet Node Name
Swimming_Pool_Load_Schedule, !- Load Schedule Name
0.0398, !- Peak Flow Rate {m3/s}
ASHRAE90.1_Schedule_H_Ventilation; !- Flow Rate Fraction Schedule Name
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:ACTUATOR ===========
Swimming_Pool_Load_Schedule_Override, !- Name
Swimming_Pool_Load_Schedule, !- Actuated Component Unique Name
Schedule:File, !- Actuated Component Type
Schedule Value; !- Actuated Component Control Type
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:PROGRAMCALLINGMANAGER ===========
EMS_PCM_Pool_Load_Schedule_Override, !- Name
AfterComponentInputReadIn, !- EnergyPlus Model Calling Point
EMS_Program_Pool_Load_Schedule_Override; !- Program Name 1
!- =========== ALL OBJECTS IN CLASS: ENERGYMANAGEMENTSYSTEM:PROGRAM ===========
EMS_Program_Pool_Load_Schedule_Override, !- Name
IF (CurrentEnvironment == 1) && (CurrentTime == 1), !- Program Line 1
SET Swimming_Pool_Load_Schedule_Override = 0, !- Program Line 2
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 2), !- A4
SET Swimming_Pool_Load_Schedule_Override = 0, !- A5
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 3), !- A6
SET Swimming_Pool_Load_Schedule_Override = 0, !- A7
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 4), !- A8
SET Swimming_Pool_Load_Schedule_Override = 0, !- A9
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 5), !- A10
SET Swimming_Pool_Load_Schedule_Override = 0, !- A11
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 6), !- A12
SET Swimming_Pool_Load_Schedule_Override = 376992.2, !- A13
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 7), !- A14
SET Swimming_Pool_Load_Schedule_Override = 0, !- A15
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 8), !- A16
SET Swimming_Pool_Load_Schedule_Override = 658.6, !- A17
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 9), !- A18
SET Swimming_Pool_Load_Schedule_Override = 170214.3, !- A19
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 10), !- A20
SET Swimming_Pool_Load_Schedule_Override = 4427.3, !- A21
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 11), !- A22
SET Swimming_Pool_Load_Schedule_Override = 83041.5, !- A23
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 12), !- A24
SET Swimming_Pool_Load_Schedule_Override = 165126.8, !- A25
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 13), !- A26
SET Swimming_Pool_Load_Schedule_Override = 5655.7, !- A27
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 14), !- A28
SET Swimming_Pool_Load_Schedule_Override = 159247.5, !- A29
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 15), !- A30
SET Swimming_Pool_Load_Schedule_Override = 8976.7, !- A31
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 16), !- A32
SET Swimming_Pool_Load_Schedule_Override = 154043.9, !- A33
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 17), !- A34
SET Swimming_Pool_Load_Schedule_Override = 12206.8, !- A35
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 18), !- A36
SET Swimming_Pool_Load_Schedule_Override = 75720.2, !- A37
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 19), !- A38
SET Swimming_Pool_Load_Schedule_Override = 159007.2, !- A39
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 20), !- A40
SET Swimming_Pool_Load_Schedule_Override = 2813.3, !- A41
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 21), !- A42
SET Swimming_Pool_Load_Schedule_Override = 159402.8, !- A43
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 22), !- A44
SET Swimming_Pool_Load_Schedule_Override = 6384.2, !- A45
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 23), !- A46
SET Swimming_Pool_Load_Schedule_Override = 150281.2, !- A47
ELSEIF (CurrentEnvironment == 1) && (CurrentTime == 24), !- A48
SET Swimming_Pool_Load_Schedule_Override = 0, !- A49
ENDIF; !- A50
