Hi,
I am running an energy simulation using OpenStudio-HPXML EUSS workflow by NREL. I ran it successfully without any errors, but no outputs were generated. Can you please help me understand the issue?
C:\Users\kkhar\Downloads\OpenStudio-HPXML-euss.2022.1 (1)\OpenStudio-HPXML-euss.2022.1>openstudio run -w workflow/template-run-hpxml-test.osw
[22:54:24.685442 WARN] No valid weather file defined in either the osm or osw. [22:54:25.594067 WARN] The model contains existing objects and is being reset. [22:54:26.608318 WARN] 'C:/Users/kkhar/Downloads/OpenStudio-HPXML-euss.2022.1 (1)/OpenStudio-HPXML-euss.2022.1/workflow/Phoenix_Arizona/upgrade0/bldg0000578-up00/G0400130-cache.csv' could not be found; regenerating it.
