Hello all,
I want to change the temperature setpoint when the experiment is running. For example, during the experiment run, can I get the real-time indoor temperature and then use some algorithm to decide what is the temperature setpoint for the next timestep?
Can anyone tell me if this is possible or do you have any solution?
Thank you so much for your help :)
