It is not very uncommon to insulate the ground floor above the slab. But I can only put the insulation below the slab in the Site:GroundDomain:Slab. Does it not really matter where the insulation is location? Or should I not include the slab in the model and just put the insulation material and the screed layer as slab material?
My actual ground floor construction is as followed:
Construction, NP_GRFloor, Brick - burned_0.11_floor, Cast Concrete (Dense)_0.075, Extruded polystyrene 25 mm_0.025_floor, Floor Screed_0.012, Ceramic/clay tiles - ceramic floor tiles Dry_0.012;
Material,
Rough,
0.11,
0.85,
1500,
840,
0.9,
0.6,
0.6;
Material,
Rough,
0.075,
1.13,
2000,
1000,
0.9,
0.6,
0.6;
Material,
Extruded polystyrene 25 mm_0.025_floor, !- Name
Rough,
0.025,
0.027,
40,
1450,
0.9,
0.4,
0.4;
Material,
Floor Screed_0.012,
Rough,
0.012,
0.41,
1200,
840,
0.9,
0.73,
0.73;
Material,
Ceramic/clay tiles - ceramic floor tiles Dry_0.012,
Rough,
0.012,
0.8,
1700,
850,
0.9,
0.6,
0.6;
