Why ZoneHVAC:Baseboard:RadiantConvective:Water has an air loop?
Hello all,
I want to simulate a simple single zone room with a single radiator unit with District Heating supplying the hot water to it. I want to use ZoneHVAC:Baseboard:RadiantConvective:Water. However, in the documentation I read that in addition to the hot water loop, there is an air loop with an air inlet and outlet node. I can not imagine it physically, how a radiator unit has an air loop. Has anyone simulated similar system before?
Thanks in advance.
Hello all,
Thanks in advance.
