Hello all,
I use the create_doe_prototype_building measure which seems to accept only a predefined list of epws. Tried to combine it with measure ChangeLocation but then it complains about not having a stat file. In the end I would just like to run the model with a custom epw. It seems basic so the answer may be out there but I could not find it, sorry about that.
Is there a simpler way ? My tentative workflow below
{ "run_directory": "run_FR_SFH_2013_system01", "measure_paths": [ "../../OpenStudio-HPXML" ], "file_paths": [ "../data" ], "steps": [ { "arguments": { "building_type": "SmallOffice", "template": "DOE Ref 1980-2004", "climate_zone": "ASHRAE 169-2013-5B", "epw_file": "MONTEREY_724915_CZ2010.epw" }, "measure_dir_name": "create_DOE_prototype_building" }, { "arguments": { "weather_file_name": "Paris_2021.epw", "climate_zone": "ASHRAE 169-2013-5B", "set_year": "2021", "use_upstream_args": true, "epw_gsub": "Do Nothing" }, "measure_dir_name": "ChangeBuildingLocation" } ], "run_options": { "fast": true, "skip_expand_objects": true, "skip_energyplus_preprocess": true } }
