Hi. I am making EMS code running right before post-processing.
I just want to calculate the comfort violation per occupied period. but the results seem to be very strange.
In ESO file, CV_Ease = 159.80 and Occ_East = 8629.01 Then RelCV_East should be 1.85 %
Also, I made EMS code for calculating CV and occupied period the following: However, Although they should be integer numbers, They seem to be double in eso files..
EnergyManagementSystem:Program, 4FE_CVCalc, !- Name IF WeekType >1 && WeekType <7, !- Program Line 1 IF Time >= 8 && Time < 19, !- Program Line 2 IF Tin_4FE > 28 || Tin_4FE < 20, !- A4 SET CV_East = CV_East + 1, !- A5 ENDIF, !- A6 ENDIF, !- A7 ENDIF; !- A8
EnergyManagementSystem:Program, 4FE_OccCalc, !- Name IF WeekType >1 && WeekType <7, !- Program Line 1 IF Time >= 8 && Time < 19, !- Program Line 2 IF NumPeople_4FE > 0, !- A4 SET Occ_East = Occ_East + 1, !- A5 ENDIF, !- A6 ENDIF, !- A7 ENDIF; !- A8
The below code is for calculating relative comfort violation codes.
EnergyManagementSystem:Program, TotalComfort, !- Name IF Mon == 12 && DayMon == 31 && Time == 23 && Min == 0, !- Program Line 1 SET RelCV_East = (CV_East / Occ_East) * 100, !- Program Line 2 SET RelCV_West = (CV_West / Occ_West) * 100, !- A4 SET RelCV_South = (CV_South / Occ_South) * 100, !- A5 SET RelCV_North = (CV_North / Occ_North) * 100, !- A6 SET Average_CV = (RelCV_East+RelCV_West+RelCV_South+RelCV_North)/4, !- A7 SET CVhr_East = (CV_East10) / 6, !- A8 SET CVhr_West = (CV_West10) / 6, !- A9 SET CVhr_South = (CV_South10) / 6, !- A10 SET CVhr_North = (CV_North10) / 6, !- A11 SET Average_CVhr = (CVhr_East+CVhr_West+CVhr_South+CVhr_North)/4, !- A12 SET Occhr_East = (Occ_East10) / 6, !- A13 SET Occhr_West = (Occ_West10) / 6, !- A14 SET Occhr_South = (Occ_South10) / 6, !- A15 SET Occhr_North = (Occ_North10) / 6, !- A16 ENDIF; !- A17
If you can teach me what is the problem, I will be very thankful to you.
thank you.
