How can I generate the coefficients for compressor performance curves (power and capacity curves)?
Is there a tool that inputs manufacturer data and outputs the curve coefficients? such as the CurveFitTool.xlsm that comes with E+.
| 1 | initial version |
| 2 | retagged |
| 3 | retagged |
Hi everyone,
How can I generate the coefficients for compressor performance curves curves (power and capacity curves)?
Is there a tool that inputs manufacturer data and outputs the curve coefficients? such as the CurveFitTool.xlsm that comes with E+. E+ that generates Bicubic curves, because the mentioned tool only has only Cubic, Quadratic, and Bi-quadratic options.
Thank you.
Hi everyone, How can I generate the coefficients for compressor performance curves (power and capacity curves)?
Is there a tool that inputs manufacturer data and outputs the curve coefficients? such as the CurveFitTool.xlsm that comes with E+ that generates Bicubic curves, because the mentioned tool only has only Cubic, Quadratic, and Bi-quadratic options.
Thank you.
Hi everyone,
How can I generate the coefficients for compressor performance curves (power and capacity curves)? (for a refrigerated warehouse model)?
Thank you.
Hi everyone,
How can I generate the coefficients for compressor performance curves (for a refrigerated warehouse model)? model)?
Thank you.
Hi everyone, How can I generate the coefficients for compressor performance curves (for a refrigerated warehouse model)?
Is there a tool that inputs manufacturer data and outputs the curve coefficients? such as the CurveFitTool.xlsm that comes with E+ that but generates Bicubic curves, because the mentioned tool only CurveFitTool has only Cubic, Quadratic, and Bi-quadratic options.
Thank you.
