How to find OSM file location from a measure?
I'm writing a measure to write CSV files to the OSM file folder and wondering if there's a way to find the location of the OSM file? Since OS uses the C:\Users\<UserName>\AppData\Local\Temp folder during a sim, using the location of the measure.rb file returns the Temp folder instead of the location of the actual OSM file. For example, a new reporting measure uses the code below to read/write to the measure folder.
html_in_path = "#{File.dirname(__FILE__)}/resources/report.html.in"
I'm using the following syntax to move up folders where __FILE__ is the measure.rb file. However, when I use puts to write the path it shows the Temp folder path.
html_root_dir = "#{File.expand_path("../../../", __FILE__)}"
I'm using the following syntax to move up folders where __FILE__ FILE is the measure.rb file. However, when I use puts to write the path it shows the Temp folder path.
I'm using the following syntax to move up folders where FILE is the measure.rb file. However, when I use puts to write the path is written out it shows the Temp folder path.
puts html_root_dir
I'm using the following syntax to move up folders where FILE is the measure.rb file. However, when the path is written out it shows the Temp folder path.
puts html_root_dir
HTML ROOT DIR = C:/USERS/MATT/APPDATA/LOCAL/TEMP/OPENSTUDIO.A17988/RESOURCES/RUN
I'm using the following syntax to move up folders where FILE is to write to a higher level of the measure.rb file. directory. However, when the path is written out it shows the Temp folder path.
puts html_root_dir
The main block of Ruby code from the measure will function as intended if executed from a terminal outside of a simulation.
I'm using the following syntax to move up folders to write to a higher level of the directory. However, when the path is written out it shows the Temp folder path.
puts html_root_dir
puts html_root_dir
