Same results for different IDF when simulated using EnergyPlus API
Hi,
I have 4500 different IDFs with different configuration.
I have to simulate it using API and cannot use traditional group simulation.
I use 'for' loop to go through 4500 IDFs and save the resulting CSV results file in a separate folder with different name.name (see code below).
for i in range(0,4499,1):
api = EnergyPlusAPI()
state = api.state_manager.new_state()
api.state_manager.reset_state(state)
api.runtime.run_energyplus(state,
'-d', 'C:/Users/4500_IDFs',
'-w', 'C:/Users/4500_IDFs/Weather_File_SYR_Modified_with_Real_Data.epw',
'-r',
'C:/Users/4500_IDFs/' + building_list[i] + '.idf'
original_file = 'eplusout.csv'
new_file = building_list[i] + '.csv'
shutil.copy(original_file, new_file)
building_list is the list containing all the file names of 4500 IDFs.
However, all of those files have the same results. How can I solve this issue?
Thanks for your time!
