Hi;
I want to do energy modeling of my desired building in the software. However, I encountered a major and serious problem in the software.
1- By changing the values of maximum and minimum temperature as well as wind speed, in the location template of the software, instead of applying the changes in the heating and cooling design tab, these changes are also applied in the simulation tab. That is, by changing the weather parameters in the location template, the cooling and heating load output values are also applied in the simulation tab, and this should not be the case.
2- By reducing the temperature and increasing the wind speed in the location template, the amount of heat consumption in winter decreases (in the simulation tab). And it is obvious that this amount should increase and the opposite happens in summer.
3 - The output values in the simulation tab should be affected by weather data (epw file) and not change by changing the values related to the location template.
Please help me to solve this problem.
Best Regards
