Hello to all,
I would like to simulate the heat demand of a building (independent from the heating system). Therefore, I want to use Ideal Air Loads. Now I am confused about the settings.
Option 1: I use the tick box "Turn on Ideal Air Loads" and a thermostat schedule (min. 21°C) --> Then I get some results for "District heating".
Option 2: I use the ZoneHVAC:IdealLoadsAirSystem. Applying that, the tick for "Turn on Ideal Air Loads" gets out automatically. - Why?
My questions: Whats the difference between these two options? Which option should I use? In case of option 2: What is the correct output I should look for?
Thank you in advance for any help!
