Hello everyone,
I'm relatively new to OS and E+ but been trying to simulate this 6 story building with a green facade using the green roof vegetation in the vertical. I am getting the same error and tried running the same model wihout the green facade which works fine. I checked everything of the green facade (construction, spaces, thermal zones etc.) and everything should be all right, or at least I can't find the issue there. When I run it, there is an eplusout.rr in the run folder but it is empty.
I feel like there is an issue with my path or PC in general but I don't know. I've been looking it up and tried some things but could not find any solution yet.
Starting Simulation.
EnergyPlus Starting
EnergyPlus, Version 22.2.0-aa78da9668, YMD=2023.01.09 14:50
Adjusting Air System Sizing
Adjusting Standard 62.1 Ventilation Sizing
Initializing Simulation
[14:50:38.475090 WARN] EnergyPlus returned a non-zero exit code. Check the stdout-energyplus log.
[14:50:38.475837 ERROR] :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus failed and did not create an eplusout.end file. Check the stdout-energyplus log., :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:236:in `call_energyplus'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in `perform'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in `step'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in `run'
:/openstudio_cli.rb:1174:in `execute'
:/openstudio_cli.rb:804:in `execute'
:/openstudio_cli.rb:1973:in `<main>'
eval:188:in `eval'
eval:188:in `require_embedded_absolute'
eval:173:in `block in require_embedded'
eval:167:in `each'
eval:167:in `require_embedded'
eval:126:in `require'
eval:3:in `<main>'
[14:50:38.477735 ERROR] Found error in state 'simulation' with message [":/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus failed and did not create an eplusout.end file. Check the stdout-energyplus log., :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:236:in `call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in `perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in `step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in `run'\n:/openstudio_cli.rb:1174:in `execute'\n:/openstudio_cli.rb:804:in `execute'\n:/openstudio_cli.rb:1973:in `<main>'\neval:188:in `eval'\neval:188:in `require_embedded_absolute'\neval:173:in `block in require_embedded'\neval:167:in `each'\neval:167:in `require_embedded'\neval:126:in `require'\neval:3:in `<main>'::/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:241:in `rescue in call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:238:in `call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in `perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in `step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in `run'\n:/openstudio_cli.rb:1174:in `execute'\n:/openstudio_cli.rb:804:in `execute'\n:/openstudio_cli.rb:1973:in `<main>'\neval:188:in `eval'\neval:188:in `require_embedded_absolute'\neval:173:in `block in require_embedded'\neval:167:in `each'\neval:167:in `require_embedded'\neval:126:in `require'\neval:3:in `<main>'"]}
Failed.
Simulation failed to run, with exit code 1
