How to correct Warnings
I have developed a model with the following warnings with no errors. However I wish to clear each one of them ( warnings with asterisk) so that after running the model it reads 0 Warnings, 0 Errors.
*** Beginning Zone Sizing Calculations * Warning * ProcessScheduleInput: ScheduleTypeLimits="CONTROLMODE", Unit Type="CONTROLMODE" is invalid. * Warning * ProcessScheduleInput: ScheduleTypeLimits="LINEARPOWERDENSITY", Unit Type="LINEARPOWERDENSITY" is invalid. * Warning * ProcessScheduleInput: ScheduleTypeLimits="VOLUMETRICFLOWRATE", Unit Type="VOLUMETRICFLOWRATE" is invalid. * Warning * ProcessScheduleInput: Schedule:Compact="HVACTEMPLATE-ALWAYS 4", Blank Schedule Type Limits Name input -- will not be validated. * Warning ** ProcessScheduleInput: Schedule:Constant="ALWAYS_ON", Blank Schedule Type Limits Name input -- will not be validated.
* Warning * Output:Meter: invalid Name="GAS:FACILITY" - not found. * Warning * Output:Meter:MeterFileOnly: invalid Name="GAS:FACILITY" - not found.
click to hide/show revision 2
No.2 Revision
*** Beginning Simulation * Warning * CalcDoe2DXCoil: Coil:Cooling:DX:SingleSpeed "CYCLING ELEC PTAC 1 SPD DX CLG COIL" - Air-cooled condenser inlet dry-bulb temperature below 0 C. Outdoor dry-bulb temperature = -3.62 * ~~~ * ... Occurrence info = RUN PERIOD 1, 01/02 08:00 - 08:10 * ~~~ * ... Operation at low ambient temperatures may require special performance curves. * Warning * CalcDoe2DXCoil: Coil:Cooling:DX:SingleSpeed "CYCLING ELEC PTAC 1 SPD DX CLG COIL" - Full load outlet air dry-bulb temperature < 2C. This indicates the possibility of coil frost/freeze. Outlet temperature = -5.09 C. * ~~~ * ...Occurrence info = RUN PERIOD 1, 01/02 08:00 - 08:10 * ~~~ * ... Possible reasons for low outlet air dry-bulb temperatures are: This DX coil * ~~~ * 1) may have a low inlet air dry-bulb temperature. Inlet air temperature = 14.517 C. * ~~~ * 2) may have a low air flow rate per watt of cooling capacity. Check inputs. * ~~~ * 3) is used as part of a HX assisted cooling coil which uses a high sensible effectiveness. Check inputs.
click to hide/show revision 3
No.3 Revision
How to correct WarningsClear Warnings after Running OS Model
I have developed a model and run with ideal air loads which gave me the following warnings with no errors. However I wish to clear each one of them ( warnings (warnings with asterisk) so that after running the model it reads 0 Warnings, 0 Errors. asterisk), Any help?
*After adding a CYCLING ELEC PTAC, the following additional warnings were realised, how can i clear this?*
How to Clear Warnings after Running OS Model
I have developed a model and run with ideal air loads which gave me the following warnings with no errors. However I wish to clear each one of them (warnings with asterisk), Any help?
click to hide/show revision 5
No.5 Revision
updated 8 years ago
rkbest's avatar
***** Beginning Zone Sizing Calculations * Warning * Calculations
** Warning ** ProcessScheduleInput: ScheduleTypeLimits="CONTROLMODE", Unit Type="CONTROLMODE" is invalid.
   * Warning * ** Warning ** ProcessScheduleInput: ScheduleTypeLimits="LINEARPOWERDENSITY", Unit Type="LINEARPOWERDENSITY" is invalid.
   * Warning * ** Warning ** ProcessScheduleInput: ScheduleTypeLimits="VOLUMETRICFLOWRATE", Unit Type="VOLUMETRICFLOWRATE" is invalid.
   * Warning * ** Warning ** ProcessScheduleInput: Schedule:Compact="HVACTEMPLATE-ALWAYS 4", Blank Schedule Type Limits Name input -- will not be validated.
   * ** Warning ** ProcessScheduleInput: Schedule:Constant="ALWAYS_ON", Blank Schedule Type Limits Name input -- will not be validated.
* Warning * validated. ** Warning ** Output:Meter: invalid Name="GAS:FACILITY" - not found. * Warning * ** Warning ** Output:Meter:MeterFileOnly: invalid Name="GAS:FACILITY" - not found.
found.
*** Beginning Simulation * Warning * Simulation
** Warning ** CalcDoe2DXCoil: Coil:Cooling:DX:SingleSpeed "CYCLING ELEC PTAC 1 SPD DX CLG COIL" - Air-cooled condenser inlet dry-bulb temperature below 0 C. Outdoor dry-bulb temperature = -3.62
 *   ~~~   * **   ~~~   **  ... Occurrence info = RUN PERIOD 1, 01/02 08:00 - 08:10
 *   ~~~   * **   ~~~   ** ... Operation at low ambient temperatures may require special performance curves.
 * Warning * ** Warning ** CalcDoe2DXCoil: Coil:Cooling:DX:SingleSpeed "CYCLING ELEC PTAC 1 SPD DX CLG COIL" - Full load outlet air dry-bulb temperature < 2C. This indicates the possibility of coil frost/freeze. Outlet temperature = -5.09 C.
 *   ~~~   * **   ~~~   **  ...Occurrence info = RUN PERIOD 1, 01/02 08:00 - 08:10
 *   ~~~   * **   ~~~   ** ... Possible reasons for low outlet air dry-bulb temperatures are: This DX coil
 *   ~~~   * **   ~~~   **    1) may have a low inlet air dry-bulb temperature. Inlet air temperature = 14.517 C.
 *   ~~~   * **   ~~~   **    2) may have a low air flow rate per watt of cooling capacity. Check inputs.
 *   ~~~   * **   ~~~   **    3) is used as part of a HX assisted cooling coil which uses a high sensible effectiveness. Check inputs.
inputs.
Calculations
*After After adding a CYCLING ELEC PTAC, the following additional warnings were realised, how can i clear this?*
