I use Energy plus that it input is IDF file. I know that skatch up uses to build building, bu how to save the file that will be created in skatch up as IDF Thanks
| 1 | initial version |
| 2 | retagged |
| 3 | No.3 Revision |
I use Energy plus EnergyPlus that it input is IDF file. I know that skatch up SketchUp uses to build building, bu but how to save the file that will be created in skatch up SketchUp as IDF
Thanks IDF.
| 4 | No.4 Revision |
I use EnergyPlus that it input is IDF file. I know that SketchUp uses to build building, but how to save the file that will be created in SketchUp as IDF.
| 5 | retagged |
