When I open large offce building Idf file that is obtained DOE commercial reference building, "Too many fields for object: FenestrationSurface:Detailed" error message is occured. In that message, the error may be fixed by adding semi-colon at the end line. But there is semi-colon at refered line. Version of large office building is 7.2 before I convert version to 9.6 by using IDFVersionUpdater. How can I fix it?
