ı m new and ı try to use Jeplus. ın result table(csv) ı can not see the outputs. ı applied step by step the videos( https://www.youtube.com/watch?v=Qmz8DnMkwdk&t=464s )
,Job_ID,WeatherFile,ModelFile,@@north@@,@@wall@@,Message,Warnings,Errors,Hours,Minutes,Seconds,c0: Heating[kWh],c1: Cooling[kWh],c2: Dıscomfort [hrs]
ı can fınd the csv folder and some data -only the outputs -Heating[kWh],c1: Cooling[kWh],c2: Dıscomfort [hrs] couldn't see the outputs ın the folder. But every sımulatıon folder ı can see the outputs with HTML. folder
