Hi,
I am trying to test thermochromic paints with only two options (darker and lighter color), under 28 degrees and over 28 degrees, but there is a severe error during the simulation.
How could I fix it?
This is the script that I am using:
<ForAllExternalSurfaces>
EnergyManagementSystem:Sensor,
Surface_Outside_Face_Temperature_<LoopSurfaceVariableName>,
<LoopSurfaceIDFName>,
Surface Outside Face Temperature;
<LoopNextSurface>
Surface_Cons_State_<LoopSurfaceVariableName>,
Surface,
Construction State;
<LoopNextSurface>
EnergyManagementSystem:ConstructionIndexVariable,
EMS_Cons_High_Abs, !- Name
High Absorptance Construction; !- Material, 3_1_10061
EMS_Cons_Low_Abs, !- Name
Low Absorptance Construction; !- Material, 19_1_10062
Thermo,
BeginTimestepBeforePredictor,
Thermo;
Thermo,
if Surface_Outside_Face_Temperature_<LoopSurfaceVariableName> < 28,
set Surface_Cons_State_<LoopSurfaceVariableName> = Material, 3_1_10061
elseif Surface_Outside_Face_Temperature_<LoopSurfaceVariableName> > 28,
set Surface_Cons_State_<LoopSurfaceVariableName> = Material, 19_1_10062,
endif,
<LoopNextSurface>
And this is the error message:
** Severe ** GetRuntimeLanguageUserInput: EnergyManagementSystem:ConstructionIndexVariable="EMS_CONS_HIGH_ABS invalid field.
** ~~~ ** Invalid Construction Object Name=HIGH ABSORPTANCE CONSTRUCTION
** ~~~ ** Construction was not found.
** Severe ** GetRuntimeLanguageUserInput: EnergyManagementSystem:ConstructionIndexVariable="EMS_CONS_LOW_ABS invalid field.
** ~~~ ** Invalid Construction Object Name=LOW ABSORPTANCE CONSTRUCTION
** Fatal ** Errors found in getting EMS Runtime Language input. Preceding condition causes termination.
Thanks! Camila
